Posted January 2, 200817 yr So I'm fixin to build a box to house an 18. I don't, however, know how to calculate my port size or to tune it. My maximum external dimensions are 35"W 30"D 17"H. I want the sub to face the ceiling of my vehicle. I don't know if thats gonna effect the port location or not. If someone could kindly walk me through the process of designing and sizing the port for my box, I'd be eternally greatful and totally post a picture log of the build process.Thanks in advance.
January 3, 200817 yr Here are couple good links for ya, first one has calculators for volumes and other things, the second one has a great port calculator.volume calculatorPort calculatorThe measurements you gave come to 8.56 cu ft. This is assuming your using 3/4" MDF, you should go with 1" and possibly double up the baffle to make sure it's stiff. With an enclosure that size your going to need internal bracing too. Don't forget to subtract the sub and port displacement when your calculating your final box size too.
January 4, 200817 yr agree...spl blazer y does ur name sound familair80maybe cause we both compete at Manny's place, and I use this name in the TermPro forums too
January 7, 200817 yr Author For some reason I'm inclined to think I did this wrong. Double check if at all possible.. on the calculator found here, [http://www.reaudio.com/speaker_box/LPort_Box_Calc.html], the red numbers from top to bottom are3530171713.6910.15Maybe I don't understand what some of these numbers really are, I was kind of hit-and-missing with that calc.. I greatly appreciate the help guys.
January 18, 200817 yr if you want to do it by hand .159 x (Sq Rt of the Vent Area(in^2) x 1.84 x 10^8 / (Enclosure Volume(in^3)(Vent Lenght(in)+.823(Sq Rt of the Vent Area(in^2)))
