Posted January 8, 200818 yr Will a fi audio ssd18 with a flatwond coil and bp power take 1600 watts daily? I would do a btl but that would be underpowered. if the fi can't take it, has anyone had experience with a 18" jaugernaut?
January 8, 200818 yr I really doubt if you send the SSD 1600w that i'll last very long. And I'm sure it'll void the warranty.Try the BL.
January 9, 200818 yr Ive heard BTLs on 1,500rms, and they still got the job done. Very efficient subs.
January 9, 200818 yr I would go for the BL. Fi has different subs because they're meant for different applications and power ranges. why buy a sub like the BTL if you arent even going to use its full potential. Where as a BL with the full options would be a much better fit. unless of course you have some sort of overall plan for upgrading the amp.
January 10, 200818 yr As far as the ssd taking that much power....doubtful it would last long, but then miguel had 4 12in SSD's with an incriminator 20.1 at .35 on each of his and bass raced it....i dont know how he wasnt blowing subs left and right
