Posted January 17, 200817 yr I have two of them, going into my next setup, only 1 pictured. HC 2000's from Kinetik... These things are heavier then sh**. Edited January 17, 200817 yr by WildSebring
January 17, 200817 yr ok now im green with ENVY Jeff i think you will find that you are louder with 2 - 15" i did the 3 15" thing and was not as loud... as i am with just 2 Edited January 17, 200817 yr by Lord Baccus
January 18, 200817 yr Author I see....it would be cheaper........You seriously think 2 would work better then 3? I want to run 3 SX 15's with 3 SAZ 1500 Sundowns. And the ZAPCO 650.6 for mids and highs. I can go with two, not a problem, but I thought three might be a little different (and louder) than the normal 2 sub setup that you see commonly.Should I go ports up, subs up like your 4 Sub box or?If you think I would meter better on 2, then talk some sense into me, because you are wiser and more knowledable than me. I'm looking to go low to mid 150's on the Meter.
January 18, 200817 yr Are you doing a wall or using your trunk? You mentioned ports and subs firing up, so I am going to guess the trunk. The space, or lack of, may quickly determine your number of drivers question. I am not too familiar with the Sebring ... how many cubic feet are available?
January 18, 200817 yr Author Well I'm selling the Sebring and buying a SUV, so space isn't an issue, sorry should have mentioned that.
January 19, 200817 yr Author Yes, you'll have to forgive me.......Tons of space to work with. I don't know if I wanna build a wall. It would produce better results probably but I don't wanna lose the vision looking backwards in my rear view.But I'll build a wall if I have to! Best believe it !
