15" Q w/ BP
Hifonics Brutus BXI 1606d
going in the trunk of a saturn vue.
15" Q w/ BP
Man i wanna learn how to model boxes, they look so cool when you do. I dont have the time to learn tho lol.
All i did was use the calculator from the link on my first post, and then drew from that guide on sketchup. is this design practical/plausible with the Q15?
Looks like a solid design... although I have never been a big fan of running more than one turn in a port.
Thanks,
Scott
If you have the tools to dado the ends of the port walls, you can use PVC to smooth them out. Works great for multiple u-turns like that.
Brian
Brian
Thanks for the input! Couple questions:
Is the 'dado' process all tablesaw work?
What's the benefit of the curved ports? better airflow, less port noise?
45's of MDF will have a simliar effect, correct?
The Dado blade is a blade that is slanted and essentially "wobbles" in the saw. Yes its a table saw.
It gives you the ability to cut a wider track in the wood without having to have a blade that is 1" to 1 1/2" thick.
Can you post the link to that calculator on here I can't find the other one.
http://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0
The calculator is at the bottom of the page, just fill in your stats.
UPDATE:
I bought the MDF, wheeled out the tablesaw and made all my cuts.
DRY FIT:
Gonna wait for the sub and the wiring terminal to come before I make any additional cuts just to be on the safe side.
