Posted January 29, 200818 yr I am looking into getting some new subs but I am stumped on what to go with. I want sq over spl. I would need 2 12's that would go in a sealed box. I also would be running from around 1000-1500 watts. My bugget is $500 for both subs. I have looked at the fi q, si mag, re se, rd classic, and infinity perfect. I could get each company new except for the si mags they'd need to be used for my price. If anyone has any suggestions please respond.
January 29, 200818 yr Used SI Mags from the last generation would be my choice out of all you listed. Almost-perfect sealed box drivers with that kind of power.
January 29, 200818 yr Don't know if you'd be willing to go SX 15's? I have a pair of them, 1's brand new ...other is lightly used.$400 for the pair plus shipping. Fs is 27.8 on them, they'd do nicely for what you want. Let me know. Edited January 29, 200818 yr by WildSebring
January 29, 200818 yr Author re sx's sq isnt that good. plus dont think 2 15's will fit in a bmw 325ci trunk. But hey I hope you have good luck selling them.
January 29, 200818 yr re sx's sq isnt that good. plus dont think 2 15's will fit in a bmw 325ci trunk. But hey I hope you have good luck selling them.I also recommend against the SXs for SQ. I second Jim's suggestion for the Mags.
January 29, 200818 yr And I agree, not really an all out SQ Subwoofer, but it isn't full blown SPL either. Just a suggestion, but it's kewl.
January 30, 200818 yr Author Yea I have read a lot of good things about the mags. So does anyone have 2 12's they want to sell?
January 30, 200818 yr Admin If you really like the MAG's, the Fi Q's are a great option. If not, used IDMAX's, SSA Icons, used Eclipse 8200LMS, SS RL-p (yes they spec out like ported only subs, but they do well sealed also). There are a few soild choices that fall into the sealed SQ sub category that can handle some power.The MAG's are not out yet, but they should do very well in a small box, not sure if a Mach5 IXL 12 will get made or not, but the 15's and 18's are reviewing really well. Also the JLW6 is a good choice, but I would worry about it on that much power. One of my all time favorites is the Crystal CMPx2, but there are mixed feelings from people about giving that driver less then 1000 watts and sealing it.
January 31, 200818 yr Author The Fi Q would be my second choice if I cant get my hands on a mag. I havnt heard much about the others that you listed tho. I am about to buy a orion 2500d so the subs would need to be able to handle it. I am also curious to what the bp power upgrade is for the Q. Edited January 31, 200818 yr by datsnowboy
January 31, 200818 yr I think there was a post explaining what each option does but not sure if it's stickied.
January 31, 200818 yr the rl-p would be a great choice with that power and sealed, i loved mine in 1.25ft^3 net.the previous gen mag is agreat SUBwoofer. make sure your mids are up to par. teh mag will give you everything you need down low!the icon is a beast, but much like the rl-p, is much more at home ported. sq wise, they both are great sealed, but do they ever come alive (output wise) portedthe classic is a good sealed box performer, but it seems the company is getting a rep for being a bit shady. mostly over not providing t/s specs pubicly. not sure if that's settled or not, but it's enough of an issue to steer clear.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
January 31, 200818 yr the q's have a good review, i run 2 out a ported box tuned to 32hz, but ive heard q's in sealed they still get really low and the sq is amazing
February 1, 200818 yr Author still cant find the post about the bp power option for the Q. If any one knows please reply.
February 1, 200818 yr Bp Power: just finished adding a new option for the SSD and Q series subs. This new option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack for a little extra mechanical ability. All of these new features increase power handling from 200-500 Watts depending on the application. Its just another way of tuning and tailoring your subs to your exact needs.Review:http://www.soundsolutionsaudio.com/forum/i...?showtopic=7135
February 1, 200818 yr BP power just enables you to run a tad more power to the Q. You don't need that for SQ.
February 1, 200818 yr Author ok so I am thinking about going with 2 12 Q's with the dual 1 ohm for each and also the bp power option on both. Then wire the coils in series and the speakers in parallel for a 1ohm final load to the orion 2500d. Now would this be to much for a sealed box? I would be using this as a daily setup.
February 1, 200818 yr You could get the BP option just to be safe and not risk burning them if you get volume happy
February 1, 200818 yr ok so I am thinking about going with 2 12 Q's with the dual 1 ohm for each and also the bp power option on both. Then wire the coils in series and the speakers in parallel for a 1ohm final load to the orion 2500d. Now would this be to much for a sealed box? I would be using this as a daily setup.That would easily overpower anything but the most extreme front stages
February 1, 200818 yr Author ok so I am thinking about going with 2 12 Q's with the dual 1 ohm for each and also the bp power option on both. Then wire the coils in series and the speakers in parallel for a 1ohm final load to the orion 2500d. Now would this be to much for a sealed box? I would be using this as a daily setup.That would easily overpower anything but the most extreme front stagesSoooo.......in newbie terms what does that mean?
February 1, 200818 yr Bass is going to be far louder than the rest of the system.Yes.i.e. not an SQ system
February 1, 200818 yr Author damn would it still have good sq tho? I am going for LSQ the more I think about it. Edited February 1, 200818 yr by datsnowboy
February 1, 200818 yr damn would it still have good sq tho? I am going for LSQ the more I think about it.LSQ still has all the features of SQ, just louder, it still has a properly set up front stage, and a sub that blends with the front and is not overbearingif you're looking for louder in the sub-bass regions with a decent sounding front, that's another thing entirely, and easily acomplishable
February 1, 200818 yr Author damn would it still have good sq tho? I am going for LSQ the more I think about it.LSQ still has all the features of SQ, just louder, it still has a properly set up front stage, and a sub that blends with the front and is not overbearingif you're looking for louder in the sub-bass regions with a decent sounding front, that's another thing entirely, and easily acomplishablewell I want to accomplish that then. Sorry I am new to all of this. So where should I start looking?
