Posted January 30, 200817 yr I was sent here by the good folks at AVS forum. I have a Sadhara sub with a blown voice coil, and they said I need a reconing on the sub. I guess Scott from Fi Car audio has worked on other XBL^2 drivers, it's possible that he may be able to help me out?Im in the dark here...so any help anyone can offer would be very helpful
January 30, 200817 yr Woah those were expensive when they came out in 2002/3.That driver was supposed to be awesome but Dan never released any real specs on the driver itself.Hopefully it's similar to the Tumult or the Brahma.. but I doubt it is.
January 30, 200817 yr Nick, it's one of their home theatre subs. About four feet tall, cylindrical wood tube, 18" in diameter. The sub was a 15" IIRC.The whole setup was passive, you had to externally amp it. Suggested power was between 300 and 800 watts.
January 30, 200817 yr I'm the one that sent the OP here.Here's the driver info from the WayBack Machine - link.That driver was supposed to be awesome but Dan never released any real specs on the driver itself. T/S parameters are in the link above.-Robert
January 31, 200817 yr Author Here are some pics of what it looks like outside of its house. It's a BEAST.From the side.From the top.So. Any ideas?
January 31, 200817 yr That a brahma with a flat back plate...Yeah we can recone it for you..what coils are you looking for?
January 31, 200817 yr Author That a brahma with a flat back plate...Yeah we can recone it for you..what coils are you looking for?I am SUCH a newb when it comes to this kind of thing, what coils do I want? It's a DVC sub...so...the kind that will be loud? I don't know really, what are my options?
January 31, 200817 yr Are you sure it's DVC? The standard was SVC 4 ohm but it's possible you have a DVC 2 ohm.
January 31, 200817 yr Author I guess I just assumed it was a DVC because it has the wire on it which I thought connected both voice coils. I'm looking for it to be 4 ohm SVC as it came.
January 31, 200817 yr Are you sure it's DVC? The standard was SVC 4 ohm but it's possible you have a DVC 2 ohm.You can see both terminal blocks in the first picture.
