Posted January 30, 200818 yr newb box helpSo I think I might be able to fit two 18" BL's @ the min. cubes of 5 per sub.just curious if I'm calculating the port disp. right...12-16" per foot, so I shot down the middle with 14", which gives me about 1/2 a cube per port, but somehow this doesn't seem big enough... so how many cubes per sub for port? thanks...
January 30, 200818 yr I'd say 31hz would be about ideal for 18's... no/yes?That'd work.That gives port length of 29.5 inches.Ignoring the displacement of the wood (will vary depending on how the port is situated), the port will take up 2.39 cubic feet
January 30, 200818 yr Author ok cool, didn't know they had a free box calc. out there...I played with the #'s a little, 44w X 25"d X 25" high, as thats about as big as I wan to go, and got 9.5 cubes, after sub disp. that leaves 9 cubes...need 10 min to do the 18". so I take a few more carefull measurements and see if I can squeeze another cube in there. if not then 15's i guess... thanks man!
