Posted February 1, 200818 yr I have 2 mtx thunder 7801d amps and was wondering if that is enough power for 1 of the Bl 18's? If yes what options should I choose for the Sub? I know I'm going to need the daily option for sure, but after that I'm lost.
February 1, 200818 yr I would get a BTL with dual 1 ohm coils.Ohm: Dual 1P Chamfer: noCooling: yes3rdMagnet: yesHiXmCoil: yesDaily or SPL: DailyUniversal: yesYou have 2400+ watts with those two amps. I would get a BTL over a BL with that much power.Brian
February 1, 200818 yr like brian said the btl will handle that power nicer, pushing 2400 to a bl is a little pushy
February 1, 200818 yr Author I would get a BTL with dual 1 ohm coils.Ohm: Dual 1P Chamfer: noCooling: yes3rdMagnet: yesHiXmCoil: yesDaily or SPL: DailyUniversal: yesYou have 2400+ watts with those two amps. I would get a BTL over a BL with that much power.BrianWhy not the Dual 2?
February 1, 200818 yr The TA7801 makes max power at 1 ohm. Buy a dual 1 ohm sub and connect one amp to each voice coil.Brian
