Posted February 1, 200818 yr Where can i buy some Knuconcept wiring at? I have googled it and cant find it.
February 1, 200818 yr Author nevermind im an idiot I spelled it wrong..... Well since this post is still up. Which Amp Installation kit should I get for an SAE-1000D amp powering 2 MAW-15's
February 1, 200818 yr at least 4 gauge... if u want to upgrade in the future then i say get 1/0 gauge to begin with so u don't have to rewire again... Edited February 1, 200818 yr by Yang
February 1, 200818 yr Author I will get the 1/0 kit because If I upgrade it will be in the summer and Im going to avoid working in the heat if I have to. the $60 or the $90 one?
February 1, 200818 yr Author Hmmm I will just stick to the 4ga then. I dont want to fudge anything up. They have 2 different 4ga amp kits. The Kolossus Fleks and the KLM kit. Which is better?
February 1, 200818 yr you can still run 1/0g wire you would either need to use a set of distro blocks and 4g wire that or 1/0g to 4g reducers
February 1, 200818 yr Author If a 4ga kit will be sufficient then I will just get that. I dont want to run extra wire if there is no need to. But yeah, what about the two diff kits.... the KLM and the Fleks kit? whats the diff and which is better?
February 1, 200818 yr I'd go with 1/0 if you can. 4ga will work but if you plan on upgrading at all you'll want the 1/0. just get a few feet of 4ga and a distro, they can be had for not very expensive.
February 7, 200817 yr Both of the Knu kits you're asking about are good, but I recommend the Fleks, just because it's so easy to work with, nice and flexible.
