I'm trying to bring the shine back to my old SS class a amps. I've started on a few fins using eagle one nevr-dull. It comes out nice but takes forever to clean up. Anyone here have a good suggestions for cleaning up aluminum?
  • Admin
All I would suggest is a non-abrasive soft soap. Then maybe some polish after.
I use a HD window cleaner on most, just spray the top and let it sit a minute. If there is goo on it then use whatever to get that off like lighter fluid/fantastic/etc. Far as shine I am not sure, an automotive 'cleaner' type compound should help with some elbow grease. I would not use anything more aggressive than that. Soft soap might work well. I have used a little lighter fluid on a rag and then used window cleaner to take most of that off. It makes it shine without the oily feel. I don't like the plastic/tire spray as they are greasy/slippery, but you might find one that is not slippery. There are some kitchen/bath products like chrome/SS cleaner that work well on certain finishes, it might work on anodize.
