dayton audio solder, hmmmmm nifty
the stuff is awsome,it has a good % of silver in it..the only
problem is it has a very high melting temp...you NEED a really
good soldiering gun for this stuff
what does it Meter @ ???
i need a table saw
Great build :slayer:
I'm not shure if he will compete with this box at all so it may
never get metered
it is tuned at 32hz..more of an SQ configuration than anything
but it will be damn loud
When you flare the port out like that, do you measure the length of the port the same? or from the start of the flare or what? Always wondered that.
Also, Just curious, when you are building a smaller airspace box, does the port have to be longer for a certain frequency than a larger box? My box has a large opening, but according with WINISD the length was very short and the box was 10cubes.
I have a formula I use for my port flares
and the port length will change with more or less port area..I build all my
enclosures with a low percentage of port velocity so the ports always
end up big azz
