I have been looking at getting a fi bl 15 for my 2002 nissan sentra and was wondering if i could fit the box needed for this sub in my trunk? Also what options should i get i want the real low deep kinda bass? and what amp would be best for my budget i would like to stay under 500 for the amp and im not sure which would be best for me and where i dont have to do the big 3 any ideas or help would be great thanks
i have been looking at a KICKER ZX1000.1 amp and also no its hard to say what can fit in my trunk cause no pics but its a mid sized 4 door car with a mid sized trunk and im just trying to get some ideas if it will fit and sound good if anyone has any ideas it would be helpful
You could measure.. that would help.
doin that now
ok i got some measurements inside the trunk is 35 inches deep 44 inches wide the opening is 18 inches high and 40 inches wide not sure what others is needed
and inside is 20 inches high my bad
Your trunk has an internal volume of 15.24^3ft.
The 15" BL in a ported box wants about 4^3ft. You'll want to tune to 30hz to get that low bass you want.
I think you have enough space.
For amps, you may as well match it up with the Sundown SAZ-1500D. Make sure you get the Dual 2 ohm option on the BL to get the most out of the amp.
You definitely need to do the big three as well as beef up your under hood battery (get something bigger/better). After those improvements, see how your electrical is doing and then decide if you want to spend the money on a High output alternator.
I was able to fit my 4.0cu.^ft box for my 15 avalanche in my little camry's trunk so you should be fine.
Edited by patented17
only thing i am stuck on now is i had another person measure the opening and he said 17 inches high is the biggest i can go the subs OD is 15.6 and the mdf is 3/4 so im at 17 1/4 i got plenty of room inside its just getting that thing in there lol i want to make this work any ideas would help
I just went to the local car audio shop and they are gonna build me a custom box for $150. Will the sub be able to handle 3000 watts from the sundown amp ? How will i no what the box is tuned to since i havent ordered the sub and amp yet. And what gauge wire should i use any idea would be great
No, the BL will not be able to handle a 3000kW amp. You'd be better off stepping up to the BTL or stepping the amp down the the SAZ-1500D.
The shop that's building the box needs to build it to Fi's spec (which can be found on their website). If they're a good shop it'll be tuned correctly. HOWEVER, you should do your own research and design (or get help designing) and build your own box.
For either amp you go with you'll need a minimum of 1/0awg wire. For the 3000D you'll also need a Larger alternator under the hood and an extra battery.
ya im gonna get the Sundown Audio SAZ 1500d amp found one for a really good price. I dont think i have the skills and tools to build my own box i told the shop what i wanted to tuned to and they said no problem.How do u find out what its tuned to? And how long will it take my sub to get here im gonna order it tomorow cause thats when the money gets in lol
ok i ordered mt sub and i got the dual one ohm how can i change that to a dual 2 ohm before it gets here i need 2 ohm for the amp im using im gonna be using the fosgate t1001bd wanna run it on 2 ohm i just orederd it like 2 hours ago or can i wire the dual one ohm for 2 ohm
Edited by timmc2006
Why did you order Dual 1 when you needed Dual2? Email [email protected] and see if you can get it changed.
Edit:
Scratch that, you told us earlier you were running the Sundown SAZ-1500D.. not the T1001BD.
You have the correct coils for that amp.
lol ya i was gonna use that amp but i found this amp for a damn good price plus i like fosgates amps. i heard that this is can put out 1500 watts is this true? i talked to the local audio installer who is building my box and he said he will install the system for 80 not to bad i guess saves me alot of time and i had no idea that the 1/0awg kit cost 150 bucks the last system i had i paid 27 bucks for the power wire thats how big of a step this is for me but does anyone no when my sub will be here ??
We don't work for Fi. When they ship it out, they'll send you a tracking number.
I hope it gets here soon it feels weird driving my car with no bass had to sell my last system got short on money and had some bills to pay. well ill let u guys no when it gets here thanks for all the help and ideas i had no idea what i was doin lol
one more guestion does any body no how many watts a t1001bd would truly put out j/w ??
its closer to 2000 below an ohm
