Posted February 14, 200818 yr I have a lot better success in making 1 single run with the port if i side fire rather then fire back.I prefer not to have to bend the port(s) is why i am asking if there is anything "off" sounding to this.My max square dimensions in cargo area is - (for this height)42" wide x 12" high x 24.25" deep.If i were leave a 7" gap in the width to allow air to escape out of the box and shoot up towards the car, i would then have-35" wide x 12" high x 24.25" deep.At the very back of the box on the side, i would, for example, have a 10.5" high x 4" wide port.I'm assuming i should have it as far back in the car as possible when side firing.If i choose to side fire, should i make the box as far deep as possible? Meaning make it the whole 24.25" deep so i can fill in the remaining cargo volume as best as possible?subs are facing up by the way.
February 15, 200818 yr Admin What vehicle?If it helps, one of the best street A guys in the world runs a single massive sewer pipe port rearward with one ten forward facing and one drivers side facing. That is in a CRX.
