Posted February 14, 200818 yr ok im a little said im some where in the range of 13.9 14.2while my car is running. and im 12.3 with the car off. i wanna be higher.. what must i do. 200 amp h/o alt3 yellow tops. big 31 run of 0 gauge3x300 amp circut breaker
February 14, 200818 yr Drop the circuit breakers for some fuses. The breakers hinder voltage slightly. Add more runs of 1/0awg.But honestly.. your numbers are fine. Those are standard voltages.
February 14, 200818 yr Those numbers look fine, now if you have enough wire to back up your power draw I don't know *don't have a clue what your setup is* but I'm guessing thats your hold up if your experiencing voltage issues.
February 14, 200818 yr Author I believe he has two 15" BL's and one SAZ-3000D that is correct sir. and i play a little here and there.. but i ordered alot of stuff so that i can play hard... this car is not my daily driver i have a company truck. so thats why progress is so slow. now the summer is comming and i gotta be ready! i was thinking if i make a few more runs and a few more yellow tops or even some powermasters. that i could bring my numbers up. i am gonna make a few more runs of 0 gauge, and see if that helps me. i had also thought about gettingf a dual alt set up. with one of the alts being 16 volts. and make a 16 volt system for my amps.. also getting another saz 3000d and getting some 15 btls, or nightshades, but thats all just thought for now...... im never happy with bass... im somthing like tha tool man taylor.... HUHUHUHU MORE POWER HUHUHUH
February 14, 200818 yr Yeah, really a 16v system is all you can do in your current situation. Good thing the Sundowns take that voltage like champs.The BTL's are a good option as well, but the NightShade... mmmm. Might as well keep it all in the Sundown family if you know what I mean.
February 14, 200818 yr Author i sure do friend. im gonna look into the nightshadeshere soon. so i got my me saz 3000 d today, while tuning i tripped my circut breaker, so im glad i had one between the amp and the cells, i got it tuned by ear best as i will today, i was worried about not having enough power with the three yellow tops and only 1 run of 0 gauge, but with the nastiest bass song i could find i was only dropping from 14.3 to 13.9 so i guess i have plenty of power! jacob again your a mad man! i love your mind and its crations.gain half way, remote at half, lowest sub sonic setting, no bass control,@1ohm. ran hard for 20 mins it was as warm as my jl 300/4 and its just pushing 2 sets of passive type r comps! i know ewwww type r Edited February 14, 200818 yr by bigjon
