Posted February 23, 200818 yr I sent an email asking this but never got a reply. I was wondering if i could seal up a SSD 15? If so what would be an ideal size for the enclosure? I checked the specs under the SSD section in the sticky thread but all i could find was "we are still testing sealed enclosures" etc. Thanks.
February 23, 200818 yr All that information is on Fi's website. Which is probably why you didn't get an email back since it's readily available.
February 23, 200818 yr Author All that information is on Fi's website. Which is probably why you didn't get an email back since it's readily available.Could you please show me where? As in a link... This is all the info i was able to find: SSD15DUAL 1 | DUAL 2Fs: 25.9 Hz | 25.3 HzRe: 0.75 Ohms/coil | 1.5 Ohms/coilQms: 4.78 | 4.89Qes: .65 | ..58Qts: .57 | .52Mms: 246g | 258gCms: 0.15mm/N | 0.15mm/NSd: 810cm^2 | 810cm^2Vas: 141.3 l | 141.3 lSpl: 87.6dB 1W/1m | 87.8dB 1W/1mBl: 9.3 N/A | 00.0 N/AXmax: 21mmRms: 800WSealed box: N/A cuftPorted box: 3-4 cuft @ 33HzSub OD: 15.625”Cut ID: 14.125”Mounting depth: 8.000”Displacement: 0.17cuftAm i missing something? Edited February 23, 200818 yr by KSlice
February 23, 200818 yr Based on the progression of box sizes for the 10" and the 12", the 15" would be somewhere around a 1^3ft-2.2^3ft.But if Fi doesn't list it.. it probably isn't recommended to seal the 15" or the 18" SSD.
February 25, 200818 yr "We are currently doing testing for sealed boxes, and I will post information if we think that it is ok to use sealed. Otherwise at this point stick to a ported enclosure."
February 25, 200818 yr I emailed you back..Give 2 cubes a shot...works good for one of our guys!Thanks!-Nick
February 25, 200818 yr Author Thank you for the email and reply. Ill give 2cF a whirl and see how it does.
