Posted February 26, 200818 yr The saturn shook it self to peices after a short stint of 1 15" RESX with a 2500.1 wired at 4 ohm, had to replace it and am moving my gear over. Need some help from people who own ford explorers or SUV's in general.Alright, i just bought a 2001 ford explorer sport.... For the sub and port directions for some loud loud daily pounding which is the best place to face the subs and the port? I plan on keeping my rear seats, making a 7 cuft box ported to 34HZ for my re SX's. Also the alt is a 130amp factory unit, i have a pair of new batts for the trunk and am runnin a KX2500.1. Do i need a larger alt if im not always hard into the amp? Thanks in advance.
February 26, 200818 yr A lot of people with those medium SUV's run port and sub both back. If you're competing, Most run sub up, port back.
February 26, 200818 yr depends on the install...if room, sub & port back is ok.most now, do sub & port up.... as stated by johnecon.go to Reaudio.com box calculator, and plug & play....depending on the batt., 2 solid models, and a 130A alt. should be ok. I'd like to see more like 200A alt., just IMO.
February 26, 200818 yr Admin In my explorer, with ported boxes, rear fire/rear port, was the best sound to me.
February 26, 200818 yr for Daily: subs & port to the rear / 152.db @ 36Hzfor Spl: subs forward ports up, box all the way back / 154.6db 52Hzfor just being obnochiously loud : subs & port up 154.1db @ 36Hz
February 28, 200818 yr The saturn shook it self to peices after a short stint of 1 15" RESX with a 2500.1 wired at 4 ohm, had to replace it and am moving my gear over. Need some help from people who own ford explorers or SUV's in general.Alright, i just bought a 2001 ford explorer sport.... For the sub and port directions for some loud loud daily pounding which is the best place to face the subs and the port? I plan on keeping my rear seats, making a 7 cuft box ported to 34HZ for my re SX's. Also the alt is a 130amp factory unit, i have a pair of new batts for the trunk and am runnin a KX2500.1. Do i need a larger alt if im not always hard into the amp? Thanks in advance.did you already buy the SX's? if you didnt, my bro has the same car, he did a half hex box, Three rear facing 12's and two in firing 12's on top.off of a 2kw amp, it really bumps.
