Posted March 16, 200818 yr Box is 13.5cuftTune to 32hzAfter subs just under 13cuftSubs are in a common chamber one large ventthis is a slot portwhat do you think aboutVENT inside areaheight 5 inWidth 39 indepth 15.5 inThis vent will be taking up 2cuft over allthis numbers were made with carstereo.com calculatoris this going to work good or do i need to rethink it againWILL TAKE ANY INFO Edited March 16, 200818 yr by YZFR1
March 16, 200818 yr you gonna need to go over that again because there is no way you only need 15.5" depth for that size port to get a 32hz tune. That's 195sq in of port.
March 22, 200817 yr Author 13.5 cuft over all12 cuft after all displacements32hz8"Height26"Width15.75"Lenththat is 208 inch port areaRight maybewill it work ?all number came from carstereo.com
