Posted March 20, 200817 yr Well i got a decent amount of money back on my taxes so its time for a new system. I have decided on a bl 15 dual 1 ohm and I just want to make sure i got this right. My enclosure is 3.5 cuft after all displacement tuned to 32hz using two 4" tube ports each 15" long. I also will be using a memphis 1500d (1500 watts at 2 ohms). Does all that sound good? Any advice on what options I should add to the sub when ordering? Thanks guys I appreciate it.
March 20, 200817 yr I come up with the port as 16". . .not much difference.I would make the ports 17" long and use the Precision Sound Ports:http://www.partsexpress.com/pe/showdetl.cf...tnumber=268-352With that much power, I would spec:Ohm: dual 1 P Chamfer: no Cooling: yes +$40 Flatwind: yes +$20 Daily or SPL: Daily Extreme Lead: no Universal: yes Brian Edited March 20, 200817 yr by BKOLFO4
