Posted March 21, 200817 yr Runing the Knukoncept 1/0tool of mass destructionjoe, playing with the subsmore goodies....getting startedlooking good, side plate last thing.time for electrical upgrades....LoadBoss 230AOld and busted vs. new hotnessI gotta fit that in there...?view from belowand abovefinishing up on box #1, final sanding....almost done... sand up the putty spots.good enough for me....time to wire them up... getting thirsty.I'll post some more "finished" pics in a bit.
March 22, 200817 yr Author Mirror shot. back seat down, Orion 2500d.... notice cable and locks on subs...going nowhere.side shot of amp & distro on other sidefront of orion 8004.back.hhhmmm.... big ports. No more cargo space...oh well, was not using it anyway.I know, not the cleanest of installs...but most of its pretty well hidden. I cant decide if I want to leave the boxes plain, or paint/maybe even a gray truck liner coat...? I'm sure I'll do something later with that but for now I'm taking a break... lots of long hours to get this far.
March 22, 200817 yr I like the fact you have em bolted in lol, good idea... Also i'd just take them out and paint em any color you want.. it'll look great.
March 22, 200817 yr how come you dident make 1 big box.Anyway it looks great and those subs look massive ...but ta i think its time for some vids
March 22, 200817 yr Author forgot to mention, its a Team Toxic Bass/ HexiBase horn loaded box design. It uses two freq. cut off ports, it has good range from 30-65Hz, but peaks somewhere from 40-45Hz. I just built it to his spec, two boxes and all, I think one would need a forklift to move it had it been made one box. I do have to say it is one off the cleanest, loudest systems I have ever heard. I would deffinatly recommend his boxes to anyone...I'll get some vids up in a little while.
March 24, 200817 yr Author Easter vids., bumping for the family.I did not quite catch the initial jolt my sis got, but you get the idea.Master P I need dubs, screwed. hit soo hard it skips at vol 25, goes to 35.It shakes the car much more than what is captured in the vids, the door handle on the inside must be flexing 1/2" or so.
March 25, 200817 yr Author todays new vids, matt used to run 3 old solo 15"s... I think he likes....I was beating the CD player to death, I brought my zune, but of course the bat. was dead. I really need to get this thing DB tested soon.
March 25, 200817 yr looks coo, i would have thought the port openings were to close to the back myself though
April 2, 200817 yr Author Grippin Grain, Rick Ross.Kinetik 2400 should be here tom. new vids after thats in, thurs, maybe. I could be able walk around a bit without having to throtle up to keep the volts up.show the car falling apart...
April 7, 200817 yr Very nice looking setup Good job. Although I'm sure the 97+ is diffrent from mine, where did you find a place to run wired through the firewall ? For the life of me, I couldn't find a single hole to run them though and ran them under the car ziptied to the brake line.
April 8, 200817 yr Author Very nice looking setup Good job. Although I'm sure the 97+ is diffrent from mine, where did you find a place to run wired through the firewall ? For the life of me, I couldn't find a single hole to run them though and ran them under the car ziptied to the brake line.there was a spot big enough to fit two runs of 1/0 high on the firewall straight back from the battery location, so that was easy...BIGJON, I have a Kinetik 2400 sitting here now, just need the time, and find somewhere to fit it... thought if could go along side of the box, but its pretty tight there... I also tried just throwing it up front in the factory location and its too big there as well.... I might just throw it on the floor behind the driver seat if nothing else... but it did hit 147.2, with just the lowly yellow top....
April 10, 200817 yr Author mo vids...pop my trunk and everybody gets to running...notice, seatbelt slap.
April 10, 200817 yr Very nice looking setup Good job. Although I'm sure the 97+ is diffrent from mine, where did you find a place to run wired through the firewall ? For the life of me, I couldn't find a single hole to run them though and ran them under the car ziptied to the brake line.there was a spot big enough to fit two runs of 1/0 high on the firewall straight back from the battery location, so that was easy...BIGJON, I have a Kinetik 2400 sitting here now, just need the time, and find somewhere to fit it... thought if could go along side of the box, but its pretty tight there... I also tried just throwing it up front in the factory location and its too big there as well.... I might just throw it on the floor behind the driver seat if nothing else... but it did hit 147.2, with just the lowly yellow top.... nice score........ nice kinetiks aswelll..... how does that orion do with the strain... hot? shutting off? i alllways liked those tc's
May 13, 200817 yr Author orion 2500D... strain?... lol.well the HC 2400 is in now, voltage stays up much better.I need to carry my camera in the car at all times to get reactions when demoing, I haven't demo'd much, maybe 20 people or so, but have had at least 3 jumpers, and most others have to plug their ears...now I just need a comp to go to...
