Posted March 22, 200817 yr alright so theres a problem that bothers the hell out of me I want an amp I am stuck between the sundown saz-1500d and the audioque aq2200d. the audioque does 2200 at 14.4v Im aware that that it would be almost impossible for me to keep that voltage .SO my main question is which one to get does anyone know what the audioque will put out at like 12.5 to 13 volts thanks for the help guys.
March 22, 200817 yr nobody knows yet, i asked the owner directly and was pretty much ignored, but the sundowns are out of stock atm as far as i know.
March 23, 200817 yr Author nobody knows yet, i asked the owner directly and was pretty much ignored, but the sundowns are out of stock atm as far as i know.yea i was just wondering
May 26, 200817 yr alright so theres a problem that bothers the hell out of me I want an amp I am stuck between the sundown saz-1500d and the audioque aq2200d. the audioque does 2200 at 14.4v Im aware that that it would be almost impossible for me to keep that voltage .SO my main question is which one to get does anyone know what the audioque will put out at like 12.5 to 13 volts thanks for the help guys.That is a great question.
May 26, 200817 yr I too am debating nearly the same thing. I really want around 4000 watts at 2 ohms so I think the audioque would be the my best bet but then it's hard to ignore the well proven track record of the 1500Ds...
May 30, 200817 yr nobody knows yet, i asked the owner directly and was pretty much ignored, but the sundowns are out of stock atm as far as i know.I didn't ignore you . I told you we had not tested the amp at 12-13 volts, but the math would indicate around 1800 at around 12.5- 13 volts. After talking with you I decided to have it AP tested at 12 voltsI have now had the amp AP tested at an EXACT 12volts with the following results:1400@12v@1%thd1800@12v@5%thd1900@12v@10%thdI wasn't trying to be evasive answering your question; I just don't like to give numbers based on estimates.dj
