Posted March 23, 200818 yr i am going to be running a memphis amp 1100 @ 1 ohm . its going in a downfire center console in a reg cab silverado . im thinking a ported 10 or a sealed 12. i have around 2 cubes to work with . im looking for a good overall response. what do you think?
March 23, 200818 yr Author With that much power and enclosure size, I would recommend the Q.how many cubes would you put a q 12 in sealed?
March 23, 200818 yr Well, if I had 2 cubes of space, I'd probably try that first, but that's just me...the upper end on Fi's recommended range is 1.5cF.
March 24, 200818 yr Author Well, if I had 2 cubes of space, I'd probably try that first, but that's just me...the upper end on Fi's recommended range is 1.5cF.i was thinking going with the fi recommended 1.1 1.2
