Posted March 27, 200818 yr what can a dual 1 ohm 18''btl fully loaded handel.can it handle a 1ohm stable amp ,0.5 ohm stable amp? i know it works with a 2ohm stableim confused . in other words how can i wire my dual 1 ohm subs to run at 1ohm or lower. and is it safe?
March 27, 200818 yr If your amp is indeed .5 ohm stable, than the sub woofer will be just fine.You wire both of the positive wires to the positive on the amp and the same for the negatives to the negative on the amp.
