Posted April 4, 200817 yr Hi guys, recently i bought some new RE Audio and USAmps equipments: 4x RE Audio 6.5CompSet, 4x RE Audio SX12" dual 4ohm, 2x MD-21 and 2x MD-3D here's a link http://forum.ecoustics.com/bbs/messages/4/468403.htmlNow I have a question about the MLT function it's says in the owners manual that the Impedance should be between 4-8ohms, I thought that the final ohm will be 2ohm since each amp will be wired to 1ohm (2 RE SX on each MD-3D), now I'm confuse what power do I get if I wired them as the owners manual shows 4ohms I wont get the full 4000wrms between the two right? because it's not wired down to 2ohms.can anybody help me out here?and the other question is about the Md-21 (2 channel) can i wire 2x Re 6.5Comp per channel thus giving them a final ohm of 2 ohm per channel will it be safe because in the owners manual it says that Impedance 4-8ohms and for mono block 1-2ohms, now can i wired them at 2ohm for stereo? anyways thanks
October 11, 200817 yr You final load on the bridged amps should be no lower than 2 ohm. The stereo amps should have no problem with 2 ohm stereo. Wire all your subs to 8 ohms and parrallel them all together. Hope this helps.
