Posted April 6, 200818 yr I just ordered a 15 bl today and im still pondering on what size box to get..do i go for a 3.0 cub box or a 4.0 cub boxany help would be greatly appreciated
April 6, 200818 yr it all depends on what you can fit, but fi recommends 2.8-4.0 cu.ft. , i would go for 3.5cu.ft tuned at 32hz,that would sound real nice,and what are you powering it with??
April 6, 200818 yr Author Im gonna power it with a RF tb1500bd at 1 ohm...i measued it in my car and the 4.0 cub box is too deep and the 3.0 seems to fit perfectly with my suv...if i put the 4.0 in it would take up lot of room and it would be around 10 to 11 inches away from the back of the my suv
April 6, 200818 yr Im gonna power it with a RF tb1500bd at 1 ohm...i measued it in my car and the 4.0 cub box is too deep and the 3.0 seems to fit perfectly with my suv...if i put the 4.0 in it would take up lot of room and it would be around 10 to 11 inches away from the back of the my suvthats a nice amp, any electrical upgrades (big3, batts,alternator), but can you fit a 3.5cu.ft?
April 6, 200818 yr Author ill probly upgrade the battery and alt depending on the cost...i need a new head unit despratley but i have to get it custom put in..and i havnt found a good 3.5 cub box online but mebe the shop im going to tomorrow will have one..
April 6, 200818 yr ill probly upgrade the battery and alt depending on the cost...i need a new head unit despratley but i have to get it custom put in..and i havnt found a good 3.5 cub box online but mebe the shop im going to tomorrow will have one..do not buy a prefab, it will sound like ish....build your own or have someone custom build it for youand if you need a headunit... check out the new eclipses on sonicelectronix.com, the give you all the instalation for free like crutchfield... these are some of the best units out right now
April 6, 200818 yr Author do any shops custom build boxes or is there a website that actual functions that i can go to..and in terms of building how long does that actually take..
April 7, 200818 yr Author Box width: 35Box Height: 17Box Top Depth: 16.5Box Bottom Depth: 16.5Wood thickness: 0.75Square Port height: 14.5Square port width: 4Square port length 1: 11.75Square port length 2: 8Total port length: 26.5it came out to 3.548 is 4 a big enough port for it or should it be 5?
April 7, 200818 yr Next issue is the subsonic filter being preset on that amp to 28Hz and a shallow 12dB per octave... fine if you are tuned 30 Hz or lower, but I would recommend adding more filtering if tuned any higher. Playing freqs below tuning is a bad thing We recommend 12-16 sqin of port per cuft. With 4X14.5 you are just a little over 16" which is plenty good. Thanks,Scott
April 7, 200818 yr Author Would that be before or after your port displacement?Thanks!-Nickwhats port displacement exactly
April 7, 200818 yr The volume the port itself takes up, i'm not quite sure how that calculator works, as i've never used it.But if you take a port that is 10" tall, 4" wide, and 10" deep, it has a volumetric displacement of .23 cubic feet (10 x 10 x 4 divided by 1728)Thanks!-Nick
April 7, 200818 yr Author The volume the port itself takes up, i'm not quite sure how that calculator works, as i've never used it.But if you take a port that is 10" tall, 4" wide, and 10" deep, it has a volumetric displacement of .23 cubic feet (10 x 10 x 4 divided by 1728)Thanks!-Nicko gotch ya this thing i used gave me that but i didnt put it in...Square port volume displaced: 1657.25
