December 7, 201015 yr glad you liked it, I had to bump up to 3scoops after 2 weeks to get the same effects.
December 7, 201015 yr i ended up buying 'jack3d'... its working great for me! im 6'1'' 190lbs... lots of energy without the side effects , its only been 10 days but i like it so far...im just getting started in this buissnes.. I'm using jack3d right now, and it works for me. I get all the boosts with no ill side effects. The only thing I cannot do is run long distance with it.The protein I am using now is BSN True Mass. Excellent taste and I have gained 10 pounds in the past month. I work out almost everyday for at least an hour. Looking to get stronger rather than put on a ton of weight, but this stuff works great.
December 8, 201015 yr Dont take this wrong, but you just said you gained 10lbs in a month, but your not trying to gain weight?!?!
December 8, 201015 yr i ended up buying 'jack3d'... its working great for me! im 6'1'' 190lbs... lots of energy without the side effects , its only been 10 days but i like it so far...im just getting started in this buissnes.. I'm using jack3d right now, and it works for me. I get all the boosts with no ill side effects. The only thing I cannot do is run long distance with it.The protein I am using now is MaBSN Truess. Excellent taste and I have gained 10 pounds in the past month. I work out almost everyday for at least an hour. Looking to get stronger rather than put on a ton of weight, but this stuff works great.im almost out of protein, im going to give BSN true mass a try...were did u get it @?
December 8, 201015 yr supplement warehouse is a good place to get stuff at and they do price match as I listed earlier in the thread enjoy.
December 8, 201015 yr cool , thanks ill check it out,,,i want to gain maybe 15lbs,., should i get a weigth gainer? or just keep lifting and wait ..? hmm,,,
December 9, 201015 yr Admin Not sure if I mentioned it, but Nitro-Tech and NO-Explod worked well for me.
December 9, 201015 yr cool , thanks ill check it out,,,i want to gain maybe 15lbs,., should i get a weigth gainer? or just keep lifting and wait ..? hmm,,,Weight gainer works great for me. Just have to stay active. I just got mine off of Amazon. They have the 5.75lb jugs for 35-40 shipped depending on the flavor.
December 12, 201015 yr Pretty much all BSN products, Also digestive enzymes are a must. There is no way your body can physically digest enough food needed for any supplement to work properly. I have been powerlifting since 2001, am 5feet 3 inches and weigh about 175 pounds. I more than likely spend more money on supplements a month than ya'll do on food. I am not very active during the day, but I still need to consume arorund 3500 calories a day to maintain my mass. Right now I am at about 10 percent body fat
January 7, 201114 yr I have tried alot of different weight gain protein/vitamin combinations and I just found onethat works freaky well (at least for me)....I am on the 4th bucket of protein and the 4th bottleof vitamins..... I started out as a skinny bonerack under 170 lbs when I got out of the hospital and Iam up to almost 200 pounds and it all came on as muscle tone..very impressed
January 9, 201114 yr I have tried alot of different weight gain protein/vitamin combinations and I just found onethat works freaky well (at least for me)....I am on the 4th bucket of protein and the 4th bottleof vitamins..... I started out as a skinny bonerack under 170 lbs when I got out of the hospital and Iam up to almost 200 pounds and it all came on as muscle tone..very impressed what was your weigth before surgery ??... i had surgery on my knee, lost 15lbs and i cant gain them back, its been 3 months...
January 9, 201114 yr I have tried alot of different weight gain protein/vitamin combinations and I just found onethat works freaky well (at least for me)....I am on the 4th bucket of protein and the 4th bottleof vitamins..... I started out as a skinny bonerack under 170 lbs when I got out of the hospital and Iam up to almost 200 pounds and it all came on as muscle tone..very impressed what was your weigth before surgery ??... i had surgery on my knee, lost 15lbs and i cant gain them back, its been 3 months...I started out at 210 pounds ripped before I started getting sickand stopped working out ......I beleive I was down to about 167 pounds at the worst...... finally starting to get by build back..............
January 11, 201114 yr I have tried alot of different weight gain protein/vitamin combinations and I just found onethat works freaky well (at least for me)....I am on the 4th bucket of protein and the 4th bottleof vitamins..... I started out as a skinny bonerack under 170 lbs when I got out of the hospital and Iam up to almost 200 pounds and it all came on as muscle tone..very impressedwhat was your weigth before surgery ??... i had surgery on my knee, lost 15lbs and i cant gain them back, its been 3 months...I started out at 210 pounds ripped before I started getting sickand stopped working out ......I beleive I was down to about 167 pounds at the worst...... finally starting to get by build back..............you have good genes/ i dont think i do...but ill give that stuff a try once i finish what im taking...
January 25, 201114 yr I have tried one combination that works even better than the one I showed here but itcomes at a much higher price range..... Herbalife weiught gain protein combined with the Male Factor , Cell Activator and their multi vitamin...probably the best nutritional products I have ever taken but friggin $$$$$ my sister uses Herbalife products and she has been in the top 3 in Canada for the past 6 or 7 yearscompeting in Natural (no steroids) Fitness competitionsonce I am back to work and can afford the stuff I will be going back to it
January 26, 201114 yr weight gainers? never believed in those. Most are packed with sugar, and you're just gonna crap it out. If u want to bulk, eat more and lift heavy
April 18, 201114 yr All you guys haven't even tapped into supplements. Its called pro hormones. Use them. And no "TREN" is not illegal. We sell it wrapped up in a ethyl gona compound and that adds size quick. Best things about pro hormones is instead for your 20lbs of size in 1 year. It happens in 1 month. That's out highest selling line up. An we have some big ass dudes on themWe carry 14 types of pro hormones. And I have never seen results off them like I have on your guys creative and protein products.
May 5, 201114 yr So I wanna hear what your favorite supplement you have EVER taken was/is. It doesn't matter what type of supplement it was, just your personal favorite.My favorite was BSN no-xplode. It gave me a great energy boost and kept me upbeat during my workout. I did also take NANO Vapor which was ridiculous from my experience. It gave me a huge boost, the downside was it made me sh*t my brains out...haha.Pre - No-Xpolde: great stuff, gives me those extra pumps and the concentration i need aswell. Post - After glow (nt sure if its one word or not): AMAZING stuff..rebuilds your muscle extremely fast, take this and you wont be sore the next day.These wont make you crazy or mean either.... lol
May 5, 201114 yr All you guys haven't even tapped into supplements. Its called pro hormones. Use them. And no "TREN" is not illegal. We sell it wrapped up in a ethyl gona compound and that adds size quick. Best things about pro hormones is instead for your 20lbs of size in 1 year. It happens in 1 month. That's out highest selling line up. An we have some big ass dudes on themWe carry 14 types of pro hormones. And I have never seen results off them like I have on your guys creative and protein products.Be careful about this guy!! Sounds like his stuff will make you crzy..... <---dont want that....dont take that ^^^^
May 8, 201114 yr All you guys haven't even tapped into supplements. Its called pro hormones. Use them. And no "TREN" is not illegal. We sell it wrapped up in a ethyl gona compound and that adds size quick. Best things about pro hormones is instead for your 20lbs of size in 1 year. It happens in 1 month. That's out highest selling line up. An we have some big ass dudes on themWe carry 14 types of pro hormones. And I have never seen results off them like I have on your guys creative and protein products.lol not to mention that youll have liver failure by 26 and wont be able to lift after that. lol there is a reason why it works so well. because its too good to be true.
