Hi,
First post here.. Looking for some help on purchasing..
I've decided on the BTL series, 18s.. I'm slightly limited on cubic space, unless I go hog wild (which is still possible) and I figure with the minimums for both being 5 cubic feet that I might as well go for the higher end (Unless the new BTLs have a different minimum, then I may have to rethink this.). I do think I am leaning more toward a daily driver, as the vehicle IS my daily driver.
The first question is with regards to ohms. I've never done a 1 amp to 1 speaker configuration so I'm confused. The amp is an Audiobahn A2200HCX amp. I will be using one to power each speaker. The amp is listed as being 1 ohm stable, but the manual for some reason doesn't list a 1x speaker configuration, though it does say that it is bridgeable. A manual for a later version of the amp (for the A2200HCT) does list a 1x config. To better explain, here's the specs from the A2200HCX manual:
INTO 4 OHMS @ 12.5V DC 2 x 200W
INTO 2 OHMS @ 12.5V DC 2 x 400W
INTO 1 OHMS @ 12.5V DC 2 x 800W
and heres the A2200HCT:
INTO 4 OHMS @ 12.5V DC 1 x 400W
INTO 2 OHMS @ 12.5V DC 1 x 800W
INTO 1 OHMS @ 12.5V DC 1 x 1600W
The 2x configs are the same, so is it safe to thing that the 1x's may also be the same, or is this a wrong thing to assume?
And to further complicate, based on the two scenarios above.. Which would be the better way to go?
A. Dual 1 Ohm, wire each voice coil to left / right of the amp,
B. Dual 2 Ohm, wire in parallel, bridged on amp, hope for best.. (This should be a 1 Ohm load correct?)
C. Some other unthought of option..
Thanks for any info.. After this I may have some box questions as well. :)
D`Arvit Reehmicks
oh god not audiobahn... man do yourself a huge favor and sell that amp and buy you a decent amp..your getting a great sub here..its like having a $150k sports car that puts out 600hp and your filling it up with 87 octane regular..to be nice has i can..that amp is crap bro
