Posted April 13, 200818 yr this is what i have first off. then the question. HU is a Kenwood Excelon XXV-01D, comps would be a set of Illusion LM-6 mids and rainbow tweets. amps would include a orion 8002 for the mids, and a orion 2002 for the tweets. NOW, for the quetions. seeing how the HU has a pretty good x-over on it. could i use that for the prossesing and use the front pre-outs for the tweets and the rear for the mids. (HU also has sub outs too) if that wouldn't work, what kinda prossesor should i use, what what kinda settings should i have it on. thanks.
April 13, 200818 yr Your deck won't control your speakers for an active setup. You'll need a 2-way crossover with a Bandpass for the mids. AudioControl makes a few decent pieces.
April 13, 200818 yr Phoenix Gold and Arc Audio also make crossovers that can be found inexpensively on Ebay or the forums.
