Posted April 21, 200818 yr can these subs handle 2000 watts daily i want them to hit hard and be heard from a distance but dont wanna blow them
April 21, 200818 yr The SSDs will be fine If you run 3 hehe. SSDs can really get movin on as little as 600 watts per, Also the SSD is an excellent sub! I own a BTL and I prefer an SSD over it but I like Quality at INSANE levels. I'd run multiple quality subs (SSD) over a single sub that can take all that power. Unless you want everyone to be amazed you only have 1 sub at the cost of SQ, or if you only have space for one sub go for multiple drivers. Q's would also be an excellent choice. 2 w no options or 1 Havoc will also do the trick.
April 21, 200818 yr Or just buy a BTL with the BP power option. Probably have a little more leeway for error.
April 21, 200818 yr Author well i got the 2 12in ssd's for a good deal but dont know wat amp to run them off and i only have a 02 maxima so not alot of space or woulda got 2 bl's
April 21, 200818 yr well i got the 2 12in ssd's for a good deal but dont know wat amp to run them off and i only have a 02 maxima so not alot of space or woulda got 2 bl'sSundown Audio SAZ-1500D would be nice..or kicker zx 1500.1...or jbl's new amp the gto 14001 model puts 1500 watts into 2 ohm and 1200 watts into 4 ohm
April 21, 200818 yr haha, you sound like one of my friends replyin like that, haha.whatever amp you choose, make sure that it's the most efficient amp you can get.I'm assuming you're not gonna be install any batts or upgradin your alt so just lettin you know.I would suggest gettin the sundown 1500d also, i know that things efficient.
April 21, 200818 yr forgot to mention that you may want to invest in a car alarm if your just wanting to be heard..
April 21, 200818 yr Author i got the dual 1 ohm model and i only wanted maybe 2000 watts though both but i goin to get a 160 amp alternator and optima battery would i need more besides the big 3
April 22, 200818 yr unless ur strapped for cash do a kinetik batt, optima doesn't push anywhere near the same amount of power
April 22, 200818 yr oooo daddy came in here and told u turn that Down! hehe.I'd run an XXV Maxximus on 2 of them.Haha, i hope you don't do that.1,500w amp will do fine.
April 22, 200818 yr Author Highly suggest not running that much power, you will run into problems.problems like wat
April 22, 200818 yr Highly suggest not running that much power, you will run into problems.problems like watwhen that man tells you not to send that much power to a sub he is very involved in you better take his advice..there are many things that can happen to your sub to keep it from playing..
April 22, 200818 yr i guess ill get either the saz-1500 or ia 20.1ia makes a great amp, but id have to go with the sun down for the price,quality, and customer support its damn hard to beat
April 22, 200818 yr Author i guess ill get either the saz-1500 or ia 20.1ia makes a great amp, but id have to go with the sun down for the price,quality, and customer support its damn hard to beatcool thanks i think i will get the saz-1500
May 1, 200817 yr unless ur strapped for cash do a kinetik batt, optima doesn't push anywhere near the same amount of powerPOWER MASTER FTW!!!!!!
