Posted April 24, 200817 yr Hey everyone. I am a new member but have been reading a lot of threads here for a while. I recently purchased a 12'' SSD with the copper coil option for my 03 S-10 ext cab. I plan on throwing the recommended RMS or more at it. I am now struggling to figure out what type of enclosure to build for it. I have read good things about sealed and ported for this subwoofer. My goal is to have a good sounding setup that has the potential to be loud if I felt the need. I want to build a ported enclosure but am afraid of port noise seeing the enclosure is in the cab with me. I can build a sealed enclosure also pending peoples thoughts on this. If anyone with knowledge on designing enclosures has a minute to get the dimensions for a ported enclosure for me that would be great. finding the volume and tuning frequency is all I know what to look for when designing a box. I know there is a lot more to do with it. The room I would like to give up:3/4'' MDFLength- no more then 28''Height- no more then 20''width- no more then 16'' I would prefer to build a slot ported box. I appreciate the help. I looked around as much as I could but could not find any plans for the SSD that fit my space requirements
April 25, 200817 yr Author Thanks for the link. So as long as the box has the same volume as recomended and tuned to 33 or so I should be good?
April 27, 200817 yr you might ask 418FIs He builds lots of custom boxes and cabinets, here is his page.http://www.soundsolutionsaudio.com/forum/i...p?showuser=2139 Edited April 27, 200817 yr by scizzle
April 27, 200817 yr I can draw something up for you.Need to clarify. . . .You have a length and a width, is width side to side (left to right), and length is depth (front to back)?Do you want the sub on top of the box, or facing forward?
April 28, 200817 yr Author hey thanks man, I should would apreciate it! Length- no more then 16'' depth Height- no more then 20'' top to bottom width- no more then 28'' side to side I think that I will need to face the sub upwards due to space constraints. Also as recomended by FI its best to design a enclosure around 1.8-2.5 cubic feet @ 33Hz. Thanks a lot
