I was told I can wire this in series to achieve 2ohms. But when I looked up a diagram for the wiring, it didn't make any sense. can someonen post a link of a good diagram?
The amp is rated at 1200 watts @2ohms. rms.
I figured this would be a perfect match for the Q.
Thanks for the help. :shrug:
Wire the coils in series..
- of one side of the sub to the positive of the other side of the sub.
Then you ook your positive and negative from your amplifier accordingly..you should have 2 terminals left with no wire in them. Hook the wire coming from the amp to those, positive, and negative respectfully.
Thats what I thought. Thank you.
Is there a visual anywhere out there?
Oh, I think I got it now.
Edited by Stu55
