How would i wire this my friend told me to get the dual 1 ohm and he knows what he's talkin about but the amp is rated at 1000 rms @ 2 ohms. Can someone tell me how to wire this
Wire the coils in series the + on one side of the sub to the - on the other side of the sub.
Then hook it up like you normally would to your amp, you will have 1 positive and 1 negative on each side of the sub with no wire in them. That is where you hook the positive and negative leads out of your amp into...
Here's a picture to help Do not pay attention to the ohm load, this is how you need to wire it.
Okay thanks guys..thats how i thought you would do it......also is that amp too much power for the ssd, i got the copper coil on it
