Posted May 1, 200817 yr So this is my first build. Box was made by mobileman at CAF.com.12" BTLCrunch GP3000D Pro2.4F Cap - Coming out when I get two Kinetic 2000sOptima Red Top1/0 wiringFatMat 1 layer in trunk, 2 on the lidSoon to beIraggi 200 amp altBig 3New comps and amp (not sure exactly)Maybe a new sub/amp layout. Will probably go with 2 12" btls with 2 GP3000D but after electrical upgrade
May 1, 200817 yr Beautiful box and nice sound deadening.Two critiquesA) Sell the cap, esp if you are doing the Big 3 AND a new alt. There should be no need for it. use the money towards a good amp, if you're going to the 2 BL set up.B) mount the amp somewhere different, or get some DARK tint on your rear window. I don't know where you live, but my stuff would be gone in .5 seconds if I rode with an amp on the rear deck. EDIT: I am dumb, saw the folded seat and thought it was the read deck haha. Amp isn't visible to thieves unless they have X-ray vision!!Just some thoughts. Good luck with it Edited May 1, 200817 yr by FocusedOnSound
May 1, 200817 yr looks great and should sound great tooget some vids up and you sure do have a lot of advertising on your car, hope you have an alarm
May 1, 200817 yr I have a 00 Accord 2dr also.Mine is is a EX v6.With the sunroof and bass, they didn't get along.I heard WAY to many rattles, so I just took all my stuff out.I hope you fixed yours.
May 1, 200817 yr well i got a 96 accord 2dr. and the sunroof was no problem at all. all i had to do was not close the inside latch all the way and it wont vibrate and rattle bad. the only problem i got is the headliner. its bad... i thought it was my sub at one point.
