Posted May 3, 200817 yr hello fi. audio can u help me choose a sub for my 2005 tiburon hatchback. ill be running one jl audio 1000v2 plus i was thinking about a ported box firing up with 2-10 or 2-12 or mayby 1-15.this is the space i have to work with 14-in (H)X16(D)X34(W)
May 3, 200817 yr That's not a lot of space for two woofers ported (3.40893^3ft GROSS). You did not give a budget, so it's gonna be kind of hard to help you.With the space you have, you might get away with an optimal enclosure for 2 SSD 10's, or a less than optimal enclosure for 2 SSD 12's. Or you can step up to 1 SSD 15".
May 4, 200817 yr A pair of 10's in the box dimensions above would work.Make a slot port on one end of the box that is 14.5 x 2.5. It will go into the box until it is 2.5" from the bottom and then turn and go another 16"With that box and amp, you could use SSD's or Q'sYou could also do a set of Q12's sealed in that box, which would sound really good. . . Edited May 4, 200817 yr by BKOLFO4
May 4, 200817 yr Author That's not a lot of space for two woofers ported (3.40893^3ft GROSS). You did not give a budget, so it's gonna be kind of hard to help you.With the space you have, you might get away with an optimal enclosure for 2 SSD 10's, or a less than optimal enclosure for 2 SSD 12's. Or you can step up to 1 SSD 15".my budjet is $450 also will a sealed box sound better in a hatchback?
May 4, 200817 yr That's not a lot of space for two woofers ported (3.40893^3ft GROSS). You did not give a budget, so it's gonna be kind of hard to help you.With the space you have, you might get away with an optimal enclosure for 2 SSD 10's, or a less than optimal enclosure for 2 SSD 12's. Or you can step up to 1 SSD 15".my budjet is $450 also will a sealed box sound better in a hatchback?what kinda music did you say u listen to?
May 4, 200817 yr Author That's not a lot of space for two woofers ported (3.40893^3ft GROSS). You did not give a budget, so it's gonna be kind of hard to help you.With the space you have, you might get away with an optimal enclosure for 2 SSD 10's, or a less than optimal enclosure for 2 SSD 12's. Or you can step up to 1 SSD 15".my budjet is $450 also will a sealed box sound better in a hatchback?what kinda music did you say u listen to?reggae,r&b,rap
May 4, 200817 yr The only hatch I have ever owned had (3) 10's sealed and it was LOUD!!I think the (2) 12's sealed woudl be more than enough. . .
May 4, 200817 yr Author The only hatch I have ever owned had (3) 10's sealed and it was LOUD!!I think the (2) 12's sealed woudl be more than enough. . .what the weight difference between the ssd 10,12and 15 and the weight difference of the Q'S 10,12,15 individually can anyone tell me?
