Posted May 5, 200817 yr Admin I have searched around a little, but I wanted to ask here in case anyone knows (Sean )of a better location other then a local junker. Someone pushed in the nose on the drivers side of Amanda's car, and it cracked the lower portion and drivers side fog lens, along with snapping the connectors into the fender well. Now the rubber scuff piece on the passenger side is scrapping the road from time to time. Since she drives this car everyday, I would rather fix this before I do brakes on the sled.
May 5, 200817 yr Author Admin The plastic is split at the bottom. I have seen at least 4 other cars with nearly the exact same break/tear in that location along with the rubber strip dangling down.
May 5, 200817 yr Urethane bumpers are easy to repair; cheap too, so if you want to try it, let me know. The wind diffuser is an easy fix as well. I don't think you have much time to repair them though, so check out this place, http://www.floydsrepairables.comMy old man said they used to have quite a good supply of German parts.
