Posted May 7, 200818 yr just ordered the new btl and was jw what the induct heat ring i put it on there but dont really know what that does
May 7, 200818 yr Its a machined aluminum ring in the gap that lowers the voicecoils inductance (allowing it to play up higher and have a little better overall transient response). It also reduces the volume inside the magnet gap of the motor increasing air speed with the cooling as well as allowing the coil to kick off heat to a more receptive thermal mass than magnets...Thanks,Scott
May 9, 200817 yr Author Its a machined aluminum ring in the gap that lowers the voicecoils inductance (allowing it to play up higher and have a little better overall transient response). It also reduces the volume inside the magnet gap of the motor increasing air speed with the cooling as well as allowing the coil to kick off heat to a more receptive thermal mass than magnets...Thanks,ScottAlight thanks another question if i ordered mine the first day they came out about how long should it take to get here
May 9, 200817 yr http://www.soundsolutionsaudio.com/forum/i...?showtopic=7158I would guess it might be an extra day or two with the extra orders for the new product. . .
May 9, 200817 yr Author http://www.soundsolutionsaudio.com/forum/i...?showtopic=7158I would guess it might be an extra day or two with the extra orders for the new product. . .yeah i saw that. i just thought they might of had some ready to go bc it was the first day they came outbut thanks thi
May 10, 200817 yr We dont stock anything (outside of the IB home drivers as they are standardized). So each sub is machined and built when ordered. Normally 3-5 business days, right now we are at 5-7 for the new BTLs. Im sure by the end of next week we will be back to 3-5 business days.Thanks,Scott
