Posted May 9, 200818 yr Hello everyone well I just orded 4 Q15s dual 1 ohm and bp power the box im building will have 2 seperate chambers, with 2 subs per chamber, with about 5 cuft per chamber,is that enough space?this is a sealed box. Also i will be using 3/4 inch MDF board to build the box, I will be putting double layers on the baffles, should I double layer all the other sides of the box or should I just brace inside to the single layers? thank you .................Brian
