Posted May 15, 200818 yr Hey yalli have a 1997 f150 with everything stock. i plan on eventually upgradeing the whole audio system. I am hopeing to get the 4 channel sundown audio amp(i dont no the exact name of it, to lazy to look it up). I also plan on buying either a 10" SSa or the Ssd subwoofer and powering it with a sundown 1000d. I have a budget of about 1200 dollars and i really dont want to up grade my alt. My question is do you all think that the 95 Amp Alt be enough to power the system with little to no light dim?Thanks in advance.
May 15, 200818 yr Just buy a Kinetik or Optima an put it near the amplifier and you should be fine...
May 16, 200818 yr figure for every thousand watts 1 extra battery. your alternator should be able to charge both your main battery and a secondary battery but I don't know if you were planning to buy another battery it would be a good idea, and it is cheaper than a capacitor and way more worth it. and you would have no light dimming problems.
