May 15, 200818 yr Author Interior is the project got save up more cashAll 0ga wiring All KnuKonceptzOptima up front 600 Amp fuse180 Amp H.O. Alternator Custom Built by Colorado AlternatorKenetics HC2000Big 32 18 BTL'S Fully Loaded14.5 cuft boxEclipse mids and tweetsEclipse EA4000 4ChannelFosgate t4000.1bd8ga Speaker Wire Edited May 15, 200818 yr by YZFR1
May 15, 200818 yr Looks like a Lumina?Should be plently loud, those are 15's?Did you use Hurculiner? I'm assuming you did it right in the car as well?
May 15, 200818 yr Author It is a lumina and the whole car is dynamat and spray damperner18's Edited May 15, 200818 yr by YZFR1
May 15, 200818 yr WOW...your own built in hair dryer...good job it is very simular to Steve Meades Honda Civic wall
May 31, 200817 yr Author got video crappy cameracan see flex click link belowhttp://www.youtube.com/user/1upR1Will have numbers tomorrow and more videos
June 2, 200817 yr Author i am in denver, cohad a show today and something was up it only tested 148.8 on some p.o.s. meter and i saw my volts drop to 9vhad alternator tested can back bad, ho alt. is coming should be here in a week next show is in 2 weeks so i should be ok
June 2, 200817 yr Damn. that's nice... on the finish.. where'd you get the dupont, and did you just use the paint or did you prime or anything else? Thanks for sharing the build
June 2, 200817 yr Author Advance auto parts did not prime the face of box, bondo the front and sanded
June 9, 200817 yr I live in Colorado Springs dude.... I want to see that setup, it's been a while since I have heard some decent 18's.. I got 2 15" BTL's in a cut-through in my pick-up
June 9, 200817 yr I live in Colorado Springs dude.... I want to see that setup, it's been a while since I have heard some decent 18's.. I got 2 15" BTL's in a cut-through in my pick-up yeah you should take it to his shop!
June 9, 200817 yr Is that supposed to be some form of sarcasm?.....Very Immature "bigon" how is that sarcasm... and even if it were how would that be immature? do you have somthing you wanna share with us? your very jumpy thumpy
