Posted May 23, 200818 yr My friend has an 04 infiniti fx 35 and wanted to know if it is possible for him to keep his stock radio which Is a bose systemon a stock 300 watt amp and just change the sub, is this possible or will he have to change out the amp too?Is it that easy, can he just replace both the amp and sub and keep the same radio?he is just looking for more bass to add to his system. I believe it has 11 speakers and 2 subs. Edited May 23, 200818 yr by scizzle
May 23, 200818 yr Admin You might have to check and see what the connections are. Some factory systems have different connectors and or wiring. As for output, if it increases, the difference will not be all that much.
May 23, 200818 yr Author You might have to check and see what the connections are. Some factory systems have different connectors and or wiring. As for output, if it increases, the difference will not be all that much.even with a bigger better amp.
May 23, 200818 yr Not at all recommended. You can keep the stock h/u, but will need an amp, an enclosure, and a sub.
