Posted May 29, 200817 yr This is the funnest sh@t iv ever had to try and read...he's just making up anything... He's High.... http://www.ddaudio.com/dd/caraudio/woofers.asp?series=zI love it...
May 29, 200817 yr kinda OT but never seen a "real" pic of the z untill today, enjoy.http://www.hexibase.com/forum/viewtopic.php?t=2883
May 29, 200817 yr Author I cant quit laughing !!!that is a great read...i like the part about the Monolyth magnets like in Space Oddicy 2001 and building a Machine to measure the watts the sub produces
May 29, 200817 yr is that serious?Features Loud Over 7 kilo-tones of effective magnetic material 3 inch diameter coil which is actually over 75mm Multi-fiber composite cone that is really strong, and red New back plate technology that is round Spatially arrayed nebular magnetic lenses Hand built by cool dudes Permendur top plate Genetically altered spiders produce a chemical blended thread of silk, polyethylene and cotton. This synthetic blend is superior to our other synthetic blend. The new synthetic blend is stronger than standard arachnid fiber, more flexible than polyunsaturated polyethylene, lighter than water (it actually floats) and yet so soft and comfortable. This material can stretch to 1.7 times its weight, allowing for un-presidential travel.and they sell these friggen things? wow.
May 30, 200817 yr Im assuming they wear hip waiters to stay above the bull and helmets to prevent further brain damage when writing these things. hahaha.
May 30, 200817 yr I can't say I blame them, those are probably the specs they came up with while drinking beer and making the webpage. Anyone who buys one of those is going to know wtf they are doing anyways, the BTL doesn't come with T/S specs...
May 30, 200817 yr i think it's a good sarcastic crack at main stream marketing and their victims. the sub can back up what ever talk they talk, so why not?
May 30, 200817 yr im thinking the same, anyone who even thinks about buying them has to know wtf they are doing.
May 30, 200817 yr Author its nice to know some companys can poke funn @ themselfs and have a sense of Humor did read it 3 times before i started cracking up
June 2, 200817 yr Dj langford made most of what your reading about the z up. He said he wanted to poke fun at all the other sub companies that tend to put bogus specs about there product and try to sell it. Looking at those pics i didnt realize that the coil was exposed like that. You can see the Pole and everything. Pretty neat.
June 2, 200817 yr Dj langford made most of what your reading about the z up. He said he wanted to poke fun at all the other sub companies that tend to put bogus specs about there product and try to sell it. Looking at those pics i didnt realize that the coil was exposed like that. You can see the Pole and everything. Pretty neat.You could see the pole and everything on my 175$ tc sounds sub too. It's ok, but nothing extra special.Another company that has a ton of humor with their manuals is audiocontrol.
June 2, 200817 yr well the added cooling you would get from it would make it pretty special IMHO. That design would be awesome with a shorter coil so that bad boy could get some more xmax going on Edited June 2, 200817 yr by Sean
June 2, 200817 yr u know i am curious...This sub costs so much money... so one would think that this might be the end all sub for just straight brutal spl...Well, why does it only have a 3" coil?A 4"coil would be able to receive a LOT more current. It can't be that a 4" makes it so inefficient that a 3" coil has better potential for higher numbers just because it may be more efficient can it?
June 2, 200817 yr im sure DD has enough experience working with 3" coils that they know how to make them take the heat.
June 2, 200817 yr The DD subs I've seen were pretty impressive. The 9500 series pounds hard as fvck and doesn't sound that bad doing it (in the right enclosure with the right power). That DDz series sub has got to be fvcking rediculous!
June 2, 200817 yr the z-series would be the LMS killer if it used a linear coil and the fs was brought down alot. But its not now in the lanes it will destroy just about anything out there, but put it in a daily application and it wouldnt do poo!
June 3, 200817 yr Check termpro forums and or check the link http://www.audiojunkies.com/blog/551/world...ingle-subwoofer
June 3, 200817 yr that is far from daily!!!!it was a reply to the OP which I didn't read anything about daily unless I missed it.
