Posted June 1, 200818 yr Was wondering what options would be best for SPl use only. Box is 10 cubic feet after port and sub displacement tuned to 54Hz. Will be using 7,000 to 10,000 watts for burps. Using 10 Kinetik 16 volt batteries and an EA Alternator. Will use either 2 15" or 18" subs.
June 1, 200818 yr Here you go compadre. Right from the sticky in the technical section.http://www.soundsolutionsaudio.com/forum/i...?showtopic=7153A few parts still correspond to the previous gen BTL, but most of them are the same.
