Posted June 1, 200818 yr Ok so this is my first time trying to build an enclosure on my own so it will probably end up looking a little rough. I started cutting yesterday and some of the pieces didnt turn out so well so I'm re-doing a few today. I will have some pics up later tonight when I finish. The enclosure will be right around 1ft^3 with a 3inch aeroport after all displacements. I'll be picking up either a 10'' Icon or 10'' bl when I get some more money. I'm looking for a daily pounder that can replace two 12'' kappa perfects that were sealed.Do the flared precision ports need a special type of 90 degree elbow in order to make a bend or can I just use any old elbow?
June 1, 200818 yr what tools are u using to cut the wood, maybe i can help you get your cuts more perfect
June 1, 200818 yr Author Yesterday I was using a jigsaw and a circular saw but my dad needed a new table saw anyways so he figured he might as well get one today. So that is going to help a ton. How long after I apply the glue should I apply the caulk? I'm using 1-5/8'' drywall screws, titebond 2, sillicon caulk, jigsaw, tablesaw, circular saw.
June 1, 200818 yr Yesterday I was using a jigsaw and a circular saw but my dad needed a new table saw anyways so he figured he might as well get one today. So that is going to help a ton. How long after I apply the glue should I apply the caulk? I'm using 1-5/8'' drywall screws, titebond 2, sillicon caulk, jigsaw, tablesaw, circular saw. dry wall screws are too fine of thread imo
June 1, 200818 yr Author Here is a picture of how its going to look....I still need to glue, screw, and caulk. I'm not putting the baffle on until I decide on which sub to get. I have 500watts @ 2ohms for temporary power until I pick up a bigger amp. I'm probably going to go with a dual 1 ohm because the new amp might not be for a little while because I still need to re-do my interior speakers, pickup 2 channel amp, get a new battery, new wires, and big 3. Also, heres a picture of my door....What would be the best place to mount the tweeters? Definitely can't do kickpanels because its a manual and I need the room down there. I'll probably get some p.g. rsd 6.5'' because I've heard good things for them being so inexpensive.
June 1, 200818 yr If the cuts are straight and you made a good glue joint, caulk is a waste. The box is sealed already for the glue. If it isn't you didn't use enough glue. I usually just run a bead of glue on the inside of any joint in addition to the glue in the joint after I get it clamped or tacked into place.
June 2, 200818 yr Author so I've got everything glued and screwed besides the top and front baffle. I'm still trying to figure out where I should have the port before I finish putting it together. The box is 8'' deep so I can either have it on the top or on the baffle. Any suggestions? How would a 10'' bl do off 500 watts for a month or so before I can get a bigger amp?
June 2, 200818 yr Author Enclosure ended up being 1.38ft^3 so after the .11 displacement for a 10'' bl and 3'' aeroport that is 13'' long ( i read add an inch if using aeroports) that displaces .053, I will be right at 1.23@33hz.
June 2, 200818 yr Author I came home from work today and caulked the joints. The top and baffle are still off because I'm going to put the port on top when it comes in and I still need to order the bl. Edited June 2, 200818 yr by KHARPS
June 2, 200818 yr Author bump, is my idea of having the port on top ok? how bout mounting locations for the tweeters in the door?
June 2, 200818 yr Author Here are some pictures of the space I have to work with and the finished box without port/mounting hole
June 3, 200818 yr Here are some pictures of the space I have to work with and the finished box without port/mounting hole man its looking good.
June 3, 200818 yr Author thanks alot......the table saw made all the difference in the world. I was getting so frustrated with the jigsaw and circular saw.
June 3, 200818 yr Author Just ordered the d1 10'' bl with p-chamfer and universal options. Thanks, Nick, for all the help and responding to my e-mails so quickly.
June 4, 200818 yr Just bolt the box to the floor of the truck with a grade 8 bolt just use some gasket maker or silicone sealant to make a air tight seal where the bolt runs thru the box. this is a little overkill but its better to be safe then sorry, you wont have to worry about the box flying around if you get into a wreck.
June 7, 200818 yr looks good, should be decently loud too!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
June 7, 200818 yr Author looks good, should be decently loud too!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee I hope so.....I went way overboard with the caulk but thats because a couple pieces were not straight and I wanted to make sure I had a good seal. I have a bunch of buddies that go to SIU so next time I'm down there I'm going to have to let you know so I can hear and see some of your work....should be in September or October.
June 7, 200818 yr cool. SIU is all of 20 minutes away, lol. though seeing and hearing some of my work might be hard to do. unless the stang is done...or i put something in either vehicle.but still get in touch.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
June 11, 200818 yr Author Painted black, looks pretty weak but it will be behind the seats anyways.I've also ordered Sundown 100.2, PG RSD 6.5'' components, Kicker PKD1 kit, (2) Knuconceptz Klarity RCAs and Karma SS speaker wire. Next paycheck will be the battery and Sundown 1500. Edited June 11, 200818 yr by KHARPS
June 11, 200818 yr Author nice car in the back ground Yeah it's a monster, barely fits in the garage. Big change of pace from the '66 427 vette he had for the last few years.
