June 7, 200817 yr Dont know about runnin the amps upside down on the roof, any problems with the amps overheating or getting hot? What series Fi's are you runnin? I had the same truck and had a hard time fittin 2 solobaric L7's 12's behind the seats.
June 7, 200817 yr Author Dont know about runnin the amps upside down on the roof, any problems with the amps overheating or getting hot? What series Fi's are you runnin? I had the same truck and had a hard time fittin 2 solobaric L7's 12's behind the seats.As far as overheating no. They
June 7, 200817 yr Author Dont know about runnin the amps upside down on the roof, any problems with the amps overheating or getting hot? What series Fi's are you runnin? I had the same truck and had a hard time fittin 2 solobaric L7's 12's behind the seats.As for the overheating issue, they get a little warm do to the fact i'm running them at 1ohm. They are the Bl's. It was a little of a tight fit but i made it work.
June 7, 200817 yr Author Looks awful so that can only mean one thing it probably gets D@MN LOUD !!!It may look a bit ruff, but your ears won't know the difference.
June 7, 200817 yr how many ft3 did you end up with after port and sub displacement. that box looks very narrow.
June 8, 200817 yr Author It is a little on the narrow side, but i still ended up with around 13cb ft after everything.
