Posted June 4, 200818 yr If i build my wall do i have to deadedn the whole car, or can i just deaden the doors and half the cabin and spray the back half with sealer or specdrum
June 5, 200818 yr Author Your idea would work fine.anyother suggestions, i wanna make sure it doesnt sound like a tin can if i don't insulate Behind the wall
June 5, 200818 yr Author Behind the wall is where your subs are. Spraying would be fine.so sray the inside of the box as well right, what i was trying to imply . is that i want to deade half the cabin and spray the other half so it comes out cheaper
June 5, 200818 yr You don't need to deaden the box. If you built it well, it's as dead as it's going to get.
June 5, 200818 yr You don't need to deaden the box. If you built it well, it's as dead as it's going to get.Bloody hell you say
June 6, 200818 yr Author You don't need to deaden the box. If you built it well, it's as dead as it's going to get.im just trying to get the most out of it . i guess ill just deadened the half ot the car with the mat and the back half with specrum or something similar.
