June 9, 200818 yr Is tuning a ported box to 35 hz for daily use normal.You port depending on your tastes. I would say that normal falls within the 32-36hz range.
June 9, 200818 yr ^^^ what he said, though i would add that the current trend is tuning around 28hz up to 32.also, tuning should depend upon equipment and goals, as well as music taste and personal taste. all in all, 35hz is a good daily driver tuning, if one doesn't mind a box that could potentially be a bit peaky.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
June 9, 200818 yr Depends on your tastes, it would make me sick at 35hz but you may not like the lack of extra peak (or boom) that you'd get if you tuned all the way up at 35hz
