Posted June 10, 200818 yr hey, im new to the forum and i dont know alot about car audio. im a marine on a DET right now and when i get home i plan on buying a new avenger or camry and im wanting some suggestions on some 12s and an amp. i listen 2rap mostly and i want something thats gunna beat pretty hard. i wanna try n keep it under 2500 too.thanx semper fi
June 10, 200818 yr 2 Fi SSD 12" woofers and a sundown Audio Saz-1500d, A decent battery and wiring. You will have money left over for sound deadening.
June 10, 200818 yr Author 2 Fi SSD 12" woofers and a sundown Audio Saz-1500d, A decent battery and wiring. You will have money left over for sound deadening.thanx I AM A check em out right now. what do u think about the fi bls? whats the diff between the 2?
June 10, 200818 yr 2 Fi SSD 12" woofers and a sundown Audio Saz-1500d, A decent battery and wiring. You will have money left over for sound deadening.thanx ima check em out right now. what do u think about the fi bls? whats the diff between the 2?You would need more amp to run Bl's and the bigger amp would require a high output alternator.2 Fi Bl 12" Dual 1 ohm woofers1 Sundown Audio Saz-3000d1 Powermaster alt2 Powermaster batteriesSound-deadening and install.
June 10, 200818 yr Author 2 Fi SSD 12" woofers and a sundown Audio Saz-1500d, A decent battery and wiring. You will have money left over for sound deadening.thanx I AM A check em out right now. what do u think about the fi bls? whats the diff between the 2?You would need more amp to run Bl's and the bigger amp would require a high output alternator.2 Fi Bl 12" Dual 1 ohm woofers1 Sundown Audio Saz-3000d1 Powermaster alt2 Powermaster batteriesSound-deadening and install.thanx for the help man i appreciate it
June 10, 200818 yr Author how would u recomend building the sub itself? cuz it lets u configure the sub how u want it???
