Would the BTL be worth the extra 200 dollars or should I just go with the BL?
BTL will need more power which means more electrical upgrades which means its way more than 200 extra dollars. I'd stick with the Bl unless you have the money to do all that.
What amp would you recommend for the BL. I'm going to upgrade my battery tomorrow and the alternator will be upgraded around August. Just trying to make slow progress.
i use a saz 3000d on my 2 15 bls
The 1500 is almost a perfect match for the loaded BL. If you will be upgrading the electrical already though and therefore you don't have to worry about buying it, you could get the BL now, maybe a 3000D, turn the gains down, and then when you feel the need for more bass upgrade to the BTL.
Do you have a budget?
I don't have a budget but the more pricey it gets the longer I have to wait until my system is done.
Would the BL be better than a T2? My friend is offering me a good deal on one and I'm not sure if I want a Rockford T2 or the BL. Their the same price, the T2 might be a little less.
