High efficiency anything is very fun.
There's a reason why I'm an unabashed Altec VOTT fanboy ;)
We all know you only like to play with 8 watts. :eek5wavey:
  • Replies 106
  • Views 13.2k
You do realize that if you put one watt into an SSD and a BTL, the BTL is louder, right? And at 10 watts, and at 100 and at 500? With the same enclosure alignment...... The efficiency rating the manufacturers gave the subs was at 1 watt, not the RMS power... Stiff spiders and all, the BTL is still the most efficient sub out there (from FI)... It is a db or so higher than all the others...
But, like I said it is a dead horse at this point... I think I'm done attempting to explaining this...
I think Neil done a little better job explaining this than you did.
You totally missunderstand anything said in this thread.
Seems, if he can't explain it well enough, nobody can.
:wackit:
LOL....
We like to keep him around though, he's cute at times...:)
