Posted October 31, 200421 yr I was loading the parameters into WinISD and noticed that there is no SPL parameter. Is it safe to just use the default one provided by WinISD? (I got 87.59 for a 12" RL-p) Also the paramenters on the site do not distinguish between 2 and 4 ohm subs. I don't think that the RE for both is 3.8.I have heard that these subs are very compairable to the Brahma. Compairing the curve on WinISD, inputing the same box size and freq., there is a big difference in performance, possibly due to the parameters I put in.Anyone got a flash light?Hey Mike, since these are a DIY sub, it might be kinda neat to have the drivers for WinISD, LEAP, BBP and other popular programs downloadable on the site.
November 1, 200421 yr I'll have more t/s parameters available coming this week. I have to run out the door now but I was skimmin' the caraudio.com forums and heard concern that I don't visit here anymore.. outrageous (and inaccurate) claims indeed! I also agree it would be very nice to integrate some of the modeling program info into my site.. which I will also work to get up there soon but I may have to head out of town for a bit later this week so let's just say it'll be up there when it'll be up there
November 2, 200421 yr Just wanted to add that WinISD is a shakey bet for calculating driver paramters. If you enter only the electro-mechanical parameters it should be allright, but I've been told only WinISD Pro Alpha offers this option.The T/S specs listed on our site are from a 4ohm unit. Though a change in the Re parameter does affect the rest of the param's, there is very little difference between a 2 and 4 ohm driver. I will, however, work to get specs up for each iteration of the drivers I currently offer.
November 11, 200421 yr Hey trixter,Finally got full specs for all my drivers which will be up on the site soon. For now, here are your sensitivity specs for the RL-p12 2ohm and 4ohm drivers:RL-p12 2ohm dvc: Sensitivity: 88.81 dBSPL max @ 1W absorbedRe: 3.7 Ohms, DC resistanceRL-p12 4ohm dvc:Sensitivity: 87.79 dBSPL max @ 1W absorbedRe: 6.26 Ohms, DC resistanceThese values are slightly different because the original values posted on the site were from a prototype driver, whereas these are tested from one of my finished production products. Give me a few days and I'll have the entire line of updated stats up on the site as well.
