Well i am fixing to give you guys a try out. I will be walling off a 93 Geo Prizm with 2 lvl 5 18's and 2 sundown 3000's. thought id post this here as i will have the car at the builders house maybe next week. Any advice on the LVL 5's. i plan to tune between 32-35hz!
Edited by Sean
honestly i am not sure what the subs need. The subs will be at the top of the wall with the port running along the bottom of the wall. Stratusrt01 will be building the wall for me starting in 2 weeks probably. I was guesstimating maybe trying to get 12-15 cubes out of the wall but im not sure!
dont be afraid to give these power,
severly underated.
so far takes 2000 rms like nothin,
next we will check it with either 2600 rms or 3000rms.
hifonics power.
2 sundown 3000's will do the trick.
Or 4 strapped 1500D's.
  • 4 weeks later...
  • 3 months later...
he would want dual 1's for daily then right? that way each of the amps is seeing a 1ohm load for a net of 2ohm per woofer? i guess for comp he'd want dual 2's so he could burp with each amp @ .5ohm and then daily the woofers with each amp seeing 2ohm loads? bleh i'm confusing myself.
  • 2 weeks later...
haha i like how you said Hifonics power.
